Drivers door lock
I have a 2013 Ridgeline RTL. My drivers door lock doesn’t unlock unless I insert the key into the lock and force the lock open and hold the key in the unlocked position. I cannot open the door from the inside using the button, it will not move from the locked position. The lock in is a locked position at all times. The unlock button on the key unlocks all the other doors but not the drivers door
Any solutions. |
Sounds like the lock actuator is stuck in closed position
Would take off door panel and investigate If it is the actuator then must be replaced or repaired Good luck |
Was my best guess to. Thanks
