Headlights Shutoff
My headlights shutoff randomly. Does not seem to matter the speed or bumps just continue to shutoff. High beams and parking lights work fine. Any suggestions?
welcome to the forum. i would try to get a hold of a wire diagram to trace all the connections on the wire bundle and try to tighten them up. you might try to have the lights on and with your hand or a stick, juggle the wire harness at joint connections to duplicate the light going off. also check inside the vehicle with someone outside watching for the lights to go off and on.
Originally Posted by acmech52
(Post 35626)
Thank you I will try this! |
Check wiring and contacts of the headlight bulbs
Check the stalk switch by rotating several times to see if anything changes |
