VTM 4 light
I have a 13 Ridgeline and I recently changed the rear differential fluid and the VTM 4 sensor. After the change the VTM 4 light still illuminates. Sometimes it does not come on until after driving for 30 or so miles. What can I do to make sure the light does not come on any more?
welcome to the forum. the VTM 4 sensor is from Honda, or aftermarket. if aftermarket, try a Honda made sensor. also is the differential fluid by Honda,.
I did use Honda fluid. As for the sensor, I dont think it matters as there are probably one manufacturer that makes these parts using the same components that Honda requires.The only difference, in my opinion, is the price you pay.
info only. sensor appears to look the same, different specifications.
