-   Sights N Sounds (https://hondaforum.com/forum/sights-n-sounds-34/)
-   -   04 Accord Radio problem (https://hondaforum.com/forum/sights-n-sounds-34/04-accord-radio-problem-5502/)
dealrocker Feb 18, 2010 06:16 AM
My cousin owns a 04 Accord. Everything is working pretty fine except the car radio. Here is the problem, it works only for 15 to 20 minutes and then shuts off with a loud cracking sound. I read somewhere; this problem may have been caused by a loose connection or short in the wiring. I check the connections manually and everything looks fine. Can't figure out how to fit this issue. Need your help to get it work properly.
Thanks in advance.
acmech52 Feb 18, 2010 11:31 PM
If you take the radio to the dealer, they will find the problem, I beleive there was a write up on the radio that it had poor solder connections in it, and many are changing out the radio to good aftermarket type. some of the radios have been repaired under estended warranty, but most swap.
