2017 crv chiming
2017 crv new problem. Car chimes when turned off. Only stops when doors closed.
Usually the chime is for warning of things like the lights are left on or key is in the ignition with the door open.
Usually, it lights up because your window has not been tightly closed or the door is not closed properly. You can take it to the garage if it lights up due to an error.
welcome to the forum. if your car is under 36k miles or less than 3 years old, you still are under warranty. do not touch the problem, but take it to the Honda Dealership to get the problem fixed.
