Grinding noise?
I have a 2004 Crv awd. Since I got it it’s made a grinding noise in the front passenger side every time I turn left. We replaced the wheel bearing, the sound is still there. A few friends have said ball joint or bushing but I have no knowledge of vehicles. Any help is appreciated!
Well, turning left and grinding noise usually means the wheel bearing is bad.
Did you jack up the wheel and put it in neutral and spin the wheel is listen for the noise? If you replaced it already then the CV axles is the only other thing I can think of that might cause such noise. Ball joints are suppose to have solid contact with the control arms And they are replaced when there is play or excessive movement. Have not heard of them making grinding noises but Don't know everything. |
