-   Sights N Sounds (https://hondaforum.com/forum/sights-n-sounds-34/)
-   -   Honda Accord Radio Cassette Removal (https://hondaforum.com/forum/sights-n-sounds-34/honda-accord-radio-cassette-removal-9235/)
HondaBug Feb 21, 2014 05:36 PM
I have an Accord 1.8i S 2001 with a factory Radio Cassette model 1SA3
I would like to replace it with another Radio/CD/MP3 player I have, but I cant work out how to remove the factory fitted one.
Have removed central column, dash lower covers, but to no avail, any isea would be appreciated
Thanks
AlexSir Dec 5, 2016 03:38 AM
I am not so sure about this model, but usually there are some Screws in front and after of the radio, you need to make sure these screws are removed before you can push the factory radio out, then you can remove the wirings and start to install a new aftermarket radio like seicane. Please check again. If you still can't find the screws, maybe it is best to take it to a repair shop to help you remove the radio and reinstall a new one. Good luck to you.
LIL G Feb 8, 2021 09:07 AM
Check with Crutch with Crutchfield ?
