400ex wont start
i have to push start my 400. it was starting fine then 1 day it wouldnt. i think it is the starter switch but i dont want 2 pay 60 bucks if thats not whts wrong.
welcome to the forum. if you have a ohm meter, check to see if you have power up to the switch, then if you have power to the starter solinoid. if there is power to both, check the solinoid for proper operation, then check the starter coil/brushes
ok thanks
400 ex start check to see if you have power up to the switch, then if you have power to the starter soli-no-id. if there is power to both, check the soli-no-id for proper operation, then check the starter coil,it work.
