-   Utility ATVs (https://hondaforum.com/forum/utility-atvs-29/)
-   -   honda foreman 450es braking problems (https://hondaforum.com/forum/utility-atvs-29/honda-foreman-450es-braking-problems-1446/)
roses15534 Apr 22, 2007 02:11 AM
when i apply my front brakes my front right tire, (wheel) locks up. I backed off the adjustments but it still locks up the front right tire not as bad but still does. It never did this before any suggestions?
acmech52 Apr 23, 2007 07:34 PM
RE: honda foreman 450es braking problems
Aloha roses 15534 check your caliper guide tubes. if they get dirty or sticky, when you release the brake, it may cause the pads from returning or freeing the disk. Using brake cleaner may help. don't spray anything on the pad or disks. And welcome to the forum. Would you have a service manual of some kind. If you go to majestichonda.com you will find the picture of the guide so you can see what to clean off.
roses15534 Apr 24, 2007 01:07 AM
acmech52they only grab when i go to stopwould that happen if they stick and dont return after stoping? also went to the website where can the pic be found?
Deleted User Dec 9, 2007 05:43 PM
[Deleted]
[Deleted by Admins]
