Utility ATVs Information about Honda's utility ATVs.
Honda Pioneer 500 (2018)
Old Jul 24, 2019 | 03:36 PM
fourtrax's Avatar
Default Honda Pioneer 500 (2018)
Parking brake light stays on with brake OFF. Where is the switch?
Old Jul 24, 2019 | 09:10 PM
Emergency brakes being on will turn brake light on
And, low brake fluid will also turn brake light on
Check those things first
Old Jul 25, 2019 | 03:44 PM
viewing the parts catalog, it appears to be under the master cylinder inside of the brake handle lever.
Old Jul 27, 2019 | 04:46 PM
fourtrax's Avatar
Default fixed
Problem was caused by the rubber sleeve for the brake lever. It had come loose from the housing and bent the little metal actuator arm on the MICROSWITCH located on the lever mechanism. Fix was to reinstall the sleeve, then readjust the metal arm on the microswitch.
Thanks all.
Old Jul 27, 2019 | 05:18 PM
thank you for your feed back, hope this will help other members.
mayhem
Jul 2, 2019 12:32 PM
danieljh
Jul 26, 2009 02:00 AM
Ltt
Jun 10, 2009 03:39 AM
tattoo432
Aug 12, 2008 08:39 AM
joe38
Dec 9, 2007 05:53 PM
