-   Utility ATVs (https://hondaforum.com/forum/utility-atvs-29/)
-   -   Honda Pioneer 500 (2018) (https://hondaforum.com/forum/utility-atvs-29/honda-pioneer-500-2018-a-13683/)
fourtrax Jul 24, 2019 03:36 PM
Parking brake light stays on with brake OFF. Where is the switch?
avisitor Jul 24, 2019 09:10 PM
Emergency brakes being on will turn brake light on
And, low brake fluid will also turn brake light on
Check those things first
acmech52 Jul 25, 2019 03:44 PM
viewing the parts catalog, it appears to be under the master cylinder inside of the brake handle lever.
fourtrax Jul 27, 2019 04:46 PM
fixed
Problem was caused by the rubber sleeve for the brake lever. It had come loose from the housing and bent the little metal actuator arm on the MICROSWITCH located on the lever mechanism. Fix was to reinstall the sleeve, then readjust the metal arm on the microswitch.
Thanks all.
acmech52 Jul 27, 2019 05:18 PM
thank you for your feed back, hope this will help other members.
