Cruising / Standard Valkyrie, VTX, Shadow, Nighthawk, and Rebel related information.
carb float cutoff adjust
Old 06-23-2017, 07:37 AM
tedburke64@gmail.com's Avatar
Default carb float cutoff adjust
nighthawk cb450sc 1982 rebuilt carbs but fuel leaks out of the air intake ports, I suspect the float needles are not adjusted right. any advise would be appreciated
Old 06-23-2017, 11:47 AM
With that age of a carbuerator Id definitely have it rebuilt or at least replace the needle / seats and bowl gaskets.. sounds like the floats may have absorbed fuel and sunk inthe float bowl.. or the needle valves are just shot.. either way a fuel leak on a bike is a dangerous situation..
Good luck!
Old 06-23-2017, 12:21 PM
Good luck!
thnx, carb has been completely disassembled, cleaned and rebuilt with all new parts. I need float adjust, but saw now way to adjust on this carb...?
mahmad55
08-17-2010 06:40 PM
franwagner
07-09-2008 04:31 PM
Ben
04-03-2007 10:04 AM
High V3l0c1ty
10-18-2006 09:53 PM
Quick Reply: carb float cutoff adjust
