Idle issue
Old 02-20-2017, 01:39 PM
lbutcher's Avatar
Default Idle issue
93 Honda Accord. After replacing motor mounts, coil, distributor and ecu the engine revs when it is put in reverse and when it shift into low gear. Timing is good, bled the coolant system, checked the tension on the throttle cable, checked the vacuum lines. Does not rev up while in park and idles aroun 850 rpm. When put in reverse it revs to around 1300. Any help would be appreciated.
bcole6
04-30-2013 09:30 AM
mikepsca
06-03-2010 12:42 PM
robstuff5
04-01-2010 07:07 AM
emmyloulou
08-06-2009 03:29 AM
allpr0h
07-14-2009 11:12 AM
Quick Reply: Idle issue
