S2000 Forum This powerful, yet efficient rear wheel drive sports car is popular among both performance car enthusiasts and the average person who wants a quick droptop.
How to replace the Clutch Master Cylinder on a S2000
Old 06-27-2011, 10:18 AM
stook00's Avatar
Default How to replace the Clutch Master Cylinder on a S2000
My clutch master cylinder decided to bail out on me like Wall Street this past weekend so I decided to replace the cursed thing myself in order to save some moolah. The job isn't too mechanically demanding- it took me and my brother about 2-3 hours to perform the job. I bought the OEM replacement for $83 at http://www.hondapartseast.com/sectio...nsmission.html so I was able to have a little beer money left over for this upcoming weekend too! But enough of my ramblings, here's a little write-up for replacing the clutch master cylinder on a S2000:
**REQUIRED TOOLS**
-Needle nosed pliers, 10mm open ended wrench, 12mm deep socket and small extension, "Crankwrench" (Mastercraft)
1) Here is the Clutch Master Cylinder (or CMC as I'll refer to it from this point forward) tucked against the firewall, underneath the blue-thingie (FMU)
2) I chose to remove the throttle cable stay when I removed my FMU. You can elect to leave the cable stay in place if you think you have sufficient room to work.
3) Next, I stuffed a bunch of newspapers under the CMC to soak up any fluid that may drip down. Then I removed the reservoir cap and sucked out as much of the fluid as I could:
4) Next, crack loose the nut that holds the fluid line onto the left side of the CMC body, but don't undo it all the way. This will help keep the fluid from dribbling until you are ready to take the CMC out.
5) The following 2 photos shows how the CMC plunger rod is attached to the clutch pedal.
First, note the specialized cotter pin on the one side:
6) This is not your typical cotter pin. You CANNOT just yank on it. It won't come. You have to grab the bigger, loopy end with needle nosed pliers and push the pin further IN to unseat the end on the curved part, then twist it 90 degrees before it will pull out. It WILL simply push straight in when it comes time to re-install.
Here's the other side. Note that the pin head is set into those tabs so the pin can't rotate around:
7) Take out the cotter pin and push out the big pin and the whole rod assembly will detach from the clutch pedal. Then remove the 2 12mm nuts that hold the CMC to the firewall. Don't drop the nuts down behind the kick panel or you'll have to remove that to get them back.
8) Now go back out and pull the CMC out a bit and completely unscrew the nut holding the fluid line in place and work the whole thing out. You'll be left with this:
9) The new CMC comes almost complete. All you need is the pedal pin and cotter pin and gasket transferred over. On the new one, the hole where the line goes in has a little plastic protective cover. Remove it:
10) Transfer that thin, rubber gasket from the old to the new:
http://inlinethumb12.webshots.com/43...600x600Q85.jpg
11) Work the new CMC back into the firewall and re-connect the fluid line while the assembly is still loose. It may take you a bit of fiddling to get the nut to start threading. DO NOT use force. Once it's lined up just right, it WILL thread on its own. Thread it in finger tight and push the CMC flush with the firewall. You may have to go inside to align the end of the rod onto the clutch pedal. Remember how the end of the rod went on. The big pin goes in from the left, so the little tabs that hold the pin head must face into the foot-well.
12) Thread the 2 nuts back onto the studs that are sticking through the firewall and snug those down. They have built-in lock washers, so no need to use gorilla strength. Don't over tighten. You'll not get a torque wrench down there, so just go by feel. Remember how tight they were when they came off?
13) You'll need to apply a little grease onto the big pedal pin. (This may be the reason why some people report a squeaky clutch pedal.) You can use the same grease that comes out of a grease gun but I just used a little silicone vacuum grease I had laying around:
14) Put the big pin into the rod assembly with it lined up with the hole in the clutch pedal. Install the specialized cotter pin. It will go from the bottom, up, if the big pin is seated in those tabs.
15) Now, go outside and tighten up the nut that holds the fluid line in the side of the CMC body. DO NOT over-tighten.
Here's the new CMC in place:
16) Finally, bleed the system. Test the clutch friction point with the engine running and in gear. You may need to do a slight adjustment on the rod that's attached to the pedal.
You'll need a 12mm open ended wrench to loosen nut ("C"). Then you grab rod ("D") with your fingers and rotate it 1/2 turn at a time to see how it affects the clutch friction point. Tighten the lock-nut each time and test. When you think you have the correct amount of free-play at the bottom and the top of the clutch travel, go for a test drive to be sure.
17) You're finished! Crack open a cold brew and enjoy the fruits of your labor
Old 07-17-2011, 07:51 PM
jessy's Avatar
hmmmmmmm.........
Old 08-09-2011, 08:02 AM
eden2000's Avatar
Old 02-21-2017, 04:12 AM
Kevin08accord's Avatar
Default Did it shear one of those cheap bolts off on the lid the triangle shapes end of the m
Originally Posted by stook00
My clutch master cylinder decided to bail out on me like Wall Street this past weekend so I decided to replace the cursed thing myself in order to save some moolah. The job isn't too mechanically demanding- it took me and my brother about 2-3 hours to perform the job. I bought the OEM replacement for $83 at www.hondapartseast.com so I was able to have a little beer money left over for this upcoming weekend too! But enough of my ramblings, here's a little write-up for replacing the clutch master cylinder on a S2000:
**REQUIRED TOOLS**
what type of fluid did you put in it?dot 3 or Honda dot 3?i think the line is getting hot and heating up the fluid in my system to high
Old 02-21-2017, 04:17 AM
[QUOTE=Kevin08accord;27982]what type of fluid did you put in it?dot 3 or Honda dot 3?i think the line is getting hot and heating up the fluid in my system to high possibly causing boiling and water vapor which raises pressure and something's gonna blow.dot 4 boils 60-80 degrees hotter than dot 3 ...I put 3 in like numerous mechanics said was fine...this is my 4 th master cylinder in 2 yrs,think I'm goin with Honda dot 4 this time around
kink_27565
04-20-2010 02:37 PM
KatieDover
01-29-2010 10:48 PM
hondaridnlow07
08-26-2009 10:55 AM
asky71
01-19-2009 08:28 AM
Dmanx1030
12-30-2008 09:42 PM
Quick Reply: How to replace the Clutch Master Cylinder on a S2000
