05 CRV error code 61
Morning,
my 05 CRV has an error code of 61, "power supply voltage failure information. low or high voltage". Any idea on why, as I've already tested the alternator and battery as being good. Thnx! |
The Haynes manual is not very useful on these types of codes.
But, the suggestion is to clear the DTC with a scanner And see if it returns. Other suggestion is to clean the battery posts and cable terminals Also follow negative cable to chassis ground, clean contacts Go to engine ground strap and clean contacts Also follow positive and inspect the connection at fuse box Clean as necessary. Remember to be safe and disconnect power when working with electrical to prevent accidents |
Thanks, On it today!
