05 CRV error code 61
Old Feb 26, 2021 | 05:52 AM
Mike Rally's Avatar
Red face 05 CRV error code 61
Morning,
my 05 CRV has an error code of 61, "power supply voltage failure information. low or high voltage". Any idea on why, as I've already tested the alternator and battery as being good.
Thnx!
Old Feb 26, 2021 | 08:40 AM
The Haynes manual is not very useful on these types of codes.
But, the suggestion is to clear the DTC with a scanner
And see if it returns.
Other suggestion is to clean the battery posts and cable terminals
Also follow negative cable to chassis ground, clean contacts
Go to engine ground strap and clean contacts
Also follow positive and inspect the connection at fuse box
Clean as necessary.
Remember to be safe and disconnect power when working with electrical to prevent accidents
Old Feb 26, 2021 | 11:00 AM
Mike Rally's Avatar
Thanks, On it today!
mrpassnh
Apr 9, 2017 11:47 PM
Salhonda
May 2, 2015 12:16 PM
C Check
Oct 9, 2009 09:49 AM
deercanbrack
Apr 24, 2008 11:24 PM
plcboy
Mar 13, 2007 01:26 AM
