1st gen rattle at varying rpm
my 98 crv AT has a rattle at varying rpm and is intermittent. Sounds just like when gravel gets between an exhaust sheild and pipe but I tried a rubber mallet all over underneath and under the hood and can't find it. one time when it was present at idle I got out and it went away...until I got back in, then it strted up every time I lifted my feet off the floor it would stp.
Another time when it was present I opened the hood and it would go away when I pressed down hard on the cam cover on the belt end...any ideas? Motor mounts? Thanks. |
does it ,the chatter speed up with your speeding up (giving it gas)jus wondering good luck
yes, with engine speed but it's present in a very narrow rpm range and not always the same range. Sometimes there when not moveing.
Originally Posted by albritton411
(Post 19293)
check your catalitic
shroud, may be loose. |
Also check all exhaust hangers.
does it get worse in the rain or after driving through a puddle ???
no rocks or cracks in shroud and hangers are good. Rain doesnt matter.
Sometimes it will go away if I take my feet off the floor and return when I put them back. Sometimes touching the belt end of the cam cover or the AC compressor makes it go away. |
Very strange.
problem solved
Just fixed the problem. Replaced all 5 engine/trans mounts. The one on the front left was broken and the others were slightly cracked. $129 on ebay.
Thanks for letting us know :D
