1st gen rattle at varying rpm
Old Oct 24, 2012 | 06:02 PM
tglenn's Avatar
Default 1st gen rattle at varying rpm
my 98 crv AT has a rattle at varying rpm and is intermittent. Sounds just like when gravel gets between an exhaust sheild and pipe but I tried a rubber mallet all over underneath and under the hood and can't find it. one time when it was present at idle I got out and it went away...until I got back in, then it strted up every time I lifted my feet off the floor it would stp.
Another time when it was present I opened the hood and it would go away when I pressed down hard on the cam cover on the belt end...any ideas? Motor mounts? Thanks.
Old Oct 24, 2012 | 06:22 PM
albritton411's Avatar
does it ,the chatter speed up with your speeding up (giving it gas)jus wondering good luck
Old Oct 24, 2012 | 08:25 PM
tglenn's Avatar
yes, with engine speed but it's present in a very narrow rpm range and not always the same range. Sometimes there when not moveing.
Old Oct 25, 2012 | 06:18 AM
check your catalitic
shroud, may be loose.
Old Oct 31, 2012 | 09:13 AM
Also check all exhaust hangers.
Old Nov 6, 2012 | 04:55 PM
lowlife9's Avatar
does it get worse in the rain or after driving through a puddle ???
Old Nov 7, 2012 | 03:08 PM
tglenn's Avatar
no rocks or cracks in shroud and hangers are good. Rain doesnt matter.
Sometimes it will go away if I take my feet off the floor and return when I put them back. Sometimes touching the belt end of the cam cover or the AC compressor makes it go away.
Old Dec 11, 2012 | 02:16 PM
Very strange.
Old Dec 12, 2012 | 04:20 PM
tglenn's Avatar
Default problem solved
Just fixed the problem. Replaced all 5 engine/trans mounts. The one on the front left was broken and the others were slightly cracked. $129 on ebay.
Old Dec 13, 2012 | 06:15 PM
  #10
Thanks for letting us know
salcuta88
Jul 22, 2014 12:07 PM
HondaAccord95
Apr 23, 2013 08:37 AM
den123
Apr 16, 2009 06:28 AM
corey
Oct 6, 2008 03:43 PM
billyburnout
Sep 10, 2006 02:15 AM
