1st gen rattle at varying rpm
my 98 crv AT has a rattle at varying rpm and is intermittent. Sounds just like when gravel gets between an exhaust sheild and pipe but I tried a rubber mallet all over underneath and under the hood and can't find it. one time when it was present at idle I got out and it went away...until I got back in, then it strted up every time I lifted my feet off the floor it would stp.
Another time when it was present I opened the hood and it would go away when I pressed down hard on the cam cover on the belt end...any ideas? Motor mounts? Thanks.
yes, with engine speed but it's present in a very narrow rpm range and not always the same range. Sometimes there when not moveing.
no rocks or cracks in shroud and hangers are good. Rain doesnt matter.
Sometimes it will go away if I take my feet off the floor and return when I put them back. Sometimes touching the belt end of the cam cover or the AC compressor makes it go away.
