2000 CRV key needs jiggling to turn
Old Apr 6, 2015 | 06:10 PM
cordovan66's Avatar
Default 2000 CRV key needs jiggling to turn
A few days ago, the ignition key to my 2000 CRV wouldn't turn. I made sure it was in park. Turning the steering wheel did not help. After 2 minutes of jiggling the key, removing and reinserting it a few times, it finally turned. I did not apply more than regular force.
Ever since, this has been happening every time I need to start the car. The condition has not gotten better or worse.
The key looks visually fine.
I read that I should put electrical contact cleaner into the key cylinder. I also read that this should not be done with some vehicles, Honda included as they have a theft deterrent system that would not take well to this treatment.
I don't know if my old (2000) vehicle has a theft deterrent system. I suspect it does not. The key is a simple one without a transponder.
Should I try cleaning out the cylinder or is it inadvisable?
Any other suggestions?
Think the key is worn? I'm inclined to think not.
Thanks
Old Apr 8, 2015 | 03:59 AM
welcome to the forum. Have you tried a spare key, normally there are 2 keys when you purchase a vehicle. Possible the switch is worn. if you have many keys on your key ring it will ware the switch.
Old Apr 8, 2015 | 05:12 PM
Welcome in,it as acmech said,try the spare key,they do wear down.
Old Apr 8, 2015 | 07:35 PM
cordovan66's Avatar
Thanks for the suggestion. Unfortunately, I don't have a spare key.
If it were gradual wear, wouldn't the problem appear slowly? The problem started abruptly.
I could get a new key made. Where would I find the key code? I don't have it on my paperwork. Can you suggest a good place to get the key made once I have the code?
Is it safe to try to clean out the lock cylinder?
Thanks again
Old Apr 12, 2015 | 07:38 AM
Take it to a locksmith,the can determine the code by resistance.
Spyke5544
Aug 3, 2010 09:52 PM
wheelin
Jul 30, 2009 09:23 PM
realdanmiller
Jun 30, 2009 06:10 PM
vilfredo
Mar 7, 2009 11:00 AM
hondacheeznoz
Sep 29, 2008 01:37 AM
