2001 crv starting issues
Old Jul 23, 2022 | 03:33 PM
Noah Roberts's Avatar
Default 2001 crv starting issues
I have an 01 crv 4wd that won’t start I replaced the crankshaft position sensor which got it running but then it sputtered and died I went through all the things and found out I had a clogged fuel filter replaced that and now it still won’t start. Had the ignition coil tested not long ago and it was good could it possibly be spark or injectors??
Old Jul 23, 2022 | 05:37 PM
Spray some starting fluid in and see if it will run for a moment. If so we know it's a fuel problem. Can you hear the fuel pump run?
Old Jul 24, 2022 | 11:08 AM
Fuel pump kicks on and runs I’ve made sure of that haven’t tried starting fluid but will
Old Jul 24, 2022 | 11:50 AM
Try the alternate fuel because a pump running does not mean it's at the correct pressure. Do you have a fuel pressure gauge?
bowhunterparamedic21
Aug 19, 2020 05:46 PM
threehondas
Jul 31, 2015 01:16 AM
jkd
Aug 24, 2013 12:58 PM
elduderino
May 10, 2013 09:00 AM
