2004 Honda Crv Keyless entry
So I have the keyless module installed behind the center console. Got it off eBay correct part #. I swapped the door lock cylinder, so now I have 2 keys but whatever, and I still can't seem to get into the program sequence. All door locks work with the interior switch, bot passenger and driver side switch. Lock and unlock. My driver side door I was under the assumption that it locks all doors from the outside? I've read that it's possible my door key switch assembly could be bad ? Also I tried checking inside the rubber boot to see if broken wires are there but damned if all I see is more rubber boot ? I see no end to the boot.
Do I need a special scan tool maybe ?
Rabelraz
Aug 19, 2021 03:45 PM
