2006 HONDA CRV Hatch dashboard light blinks
Old Aug 10, 2016 | 08:11 PM
jdecas78@gmail.com's Avatar
Default 2006 HONDA CRV Hatch dashboard light blinks
A few days ago when i was driving,i noticed the warning light on my dashboard would flicker when i hit bumps or turn. The light was indicating that my hatch or truck may be open. Problem is,they are closed shut. This warning light only flickers when i hit bumps or make a turn. Once again my truck and hatch window are closed. What could be the problem? And how much will it cost to fix? My Honda CRV 2006 has 153,339KM on it. Thanks.
Old Aug 10, 2016 | 09:38 PM
Hondadda's Avatar
When your hatch closes it presses on a switch to tell the computer the hatch is closed. Locate this switch it looks like this:
https://goo.gl/images/V41TV0
This image is for a 1st gen crv but its the same in 2nd gen
I fixed mine by adjusting the rubber grommet on the switch. I had the same problem. You could also add a few layers of tape to the rubber
Old Aug 10, 2016 | 09:43 PM
Do i have to remove the switch? Wont i damage it if i do remove it?
Old Aug 10, 2016 | 09:44 PM
Hondadda's Avatar
No its exposed. Inspect it first. See if the rubber cover is coming off. It may be as simple as sliding the cover back into place
Old Aug 10, 2016 | 09:46 PM
This switch is located on this inside latch? Ill tomorrow.
Old Aug 10, 2016 | 09:49 PM
Hondadda's Avatar
No its exposed the gate edge presses on it. Its on the left side inner side of the tailgate about half way up
Old Aug 10, 2016 | 10:06 PM
I'll try tomorrow. I checked online and these switches don't cost much either. Hope I don't have to change the switch. What tape did you use?
Old Aug 10, 2016 | 10:07 PM
Hondadda's Avatar
I used a rubber stick pad from the 99 cents store. I put under the rubber cover making a little bump in the rubber. It fixed the problem. 5 minutes of work and 99 cents
Old Aug 11, 2016 | 04:22 AM
Sabrina Susan's Avatar
Smile OpenStack Training
OpenStack is a free and open-source software platform¬¬¬¬ for cloud computing, mostly deployed as an infrastructure-as-a-service.| https://goo.gl/z0JFB7
https://goo.gl/WzKGr2
https://goo.gl/pO7P7J
https://goo.gl/Tshw0J
https://goo.gl/HZJgxn
Old Apr 13, 2020 | 12:05 PM
  #10
Tlaw's Avatar
I added small piece of foam/ tape to switch plunger.
Problem solved.
bobinyelm
Sep 9, 2017 07:05 PM
robertmaiker
Apr 28, 2017 09:41 AM
djletin
May 24, 2009 08:58 PM
Zackcal1899
Jan 24, 2008 10:17 PM
914b16
Dec 2, 2006 08:16 PM
