2007 Honda CR-V engine noise
133k kms, change oil 750km ago with Pennzoil Ultra Platinum 0w-20 (for West Canadian winter) and Denso filter, own this vehicle from 95k km, no oil consumption.
Start some noise today while driving in the city, 50-60 km/h. really hear at 1200-1800 rpm. Sometimes louder, sometimes quieter
I record video, clicking noise it's probably normal valves work. Bad noise on background.
Hard to find good engine mechanic in my area so looking for any idea what is can happen?
welcome to the forum. little to much noise from all engine. if the noise if from the front of the engine, opposite side of the transmission, it could be water pump, timing belt tensioner. if you can, go to the auto shop and purchase a stethoscope , it looks like what the doctors/nurse use but has couple of long metal screw together rods so you can pin point closer to where the noise is coming from.. it could also be an alternator bearing. or if you have a serpentine belt, that tensioner also. difficult to know exactly where the noise is coming from. also could be the a/c clutch plate.
I have the 2007 Crv and it sounds exactly the same.
Got it with 88k miles and recently topped 100k miles.
It does sound like the valves.
Was figuring on putting Seafoam through the engine oil
Have already done the fuel system a couple of times.
Don't know if it will help.
Oh, want to change the serpentine belt since it was never changed before.
