2008 CR-V Front hub.
Old Nov 13, 2020 | 01:39 PM
Gary Born's Avatar
Unhappy 2008 CR-V Front hub.
I have got to remove this hub so I can replace a couple wheel studs. I borrowed a nice slide hammer from Advance Auto. I can't get this hub to budge. Of course I removed the axle nut first. What else can I do or try? Any advice would be helpful.
Old Nov 13, 2020 | 02:33 PM
after the axle nut removed, there is a cir-clip to remove.
Old Nov 13, 2020 | 02:40 PM
Gary Born's Avatar
I am trying to pull only the hub. Not the bearing. Thank you
Old Nov 13, 2020 | 03:15 PM
Are there bolts holding the wheel hub onto the knuckle??
There are various tools available
One is the slide hammer which takes lots of luck and force to get wheel hubs off
Of course these things are not cheap. Especially if you are only using them once or twice.
My favorite is the "hub shocker". Or you could try the "OTC hub grappler".
Sometimes, if it isn't stuck on too hard then, ...
You can cut a stud or two and knock them out of the hub.
Then, you can put in bolts and nuts to push the hub outward.
The bolt goes thru the hole where the stud was. A nut goes on the other side(between the hub and knuckle)
Screw in the bolt and the nuts holds against the hub.
Using hand tools, it should push the hub out.
If it feels like it is going to break then stop
Also, watch for any deformation of hub or knuckle.
Good luck
Note: It is very hard not to pull out the bearing also.
Forget what I said about using anything.
You are on your own
Old Nov 13, 2020 | 03:25 PM
Gary Born's Avatar
I will look at "hub shocker"
Gary Born
Sep 12, 2020 07:03 PM
Brian Coburn
Nov 12, 2018 04:30 PM
Benst
Jan 11, 2013 10:15 PM
suzy fisher
Dec 1, 2008 06:28 PM
davidLX
Nov 30, 2006 06:11 PM
