2009 CRV water pump replacement
Old Oct 3, 2018 | 11:58 AM
cookieman's Avatar
Default 2009 CRV water pump replacement
New water pump has rubber seal any sealant / grease needed to lube seal before installing pump
Old Oct 3, 2018 | 01:58 PM
welcome to the forum i did not see any instructions to put sealant or lube. just make sure the surfaces are clean.
Old Oct 4, 2018 | 12:00 PM
cookieman's Avatar
many water pump brands. Gates GMB, Beck Arnley, what are the best lasting up to 100k, what about the Aisin brand web site says to soak in water before installing because it has a carbon ceramic seal. any knowledge or experience any better.
Old Oct 4, 2018 | 12:40 PM
i have used all brands of after market parts, non in particular go bad. each type of part has its own instructions of installation. so i now just go to oem for the vehicle i am working on. if for my Fit and Hrv, all honda parts. it lasted for xxx miles, a new one should go for just about as long. only things that must be honda is the transmission oil and exhaust sensors, if you go after market on those two it is a good failure to come.
Old Oct 4, 2018 | 04:57 PM
cookieman's Avatar
Thanks again
jro
Sep 1, 2009 07:51 AM
buttacup79
Nov 17, 2008 07:04 PM
Bocatrip
Nov 1, 2007 09:48 AM
unclewilco
Aug 15, 2006 08:40 PM
91accordf22a
May 28, 2006 09:17 PM
