2010 a/c problem
Old Apr 22, 2018 | 01:33 PM
lilbull's Avatar
Default 2010 a/c problem
the a/c does not always come on when the inside controls are set for it. when it does kick in it works fine. there seems to be no rhyme or reason to when it will work or not. try it no go. stop at store come out then it will work. what do I need to check. like I said it works great when it works so I know it is not low on freon.
Old Apr 22, 2018 | 06:42 PM
welcome to the forum. check the thermister. it is near the fan in the duct held on by 2 screws. it is like a resistor. a spring with ceramic coating.
Old Apr 22, 2018 | 08:20 PM
lilbull's Avatar
Default A.c. thermistor
Is there a way to electrically check these. Can u get them at auto parts store
Old Apr 24, 2018 | 10:59 PM
use an ohm meter to check continuity. yes auto parts store have them, you can usually visually see when damaged.
Onejim
Aug 5, 2015 06:08 PM
ridelisa
Apr 20, 2009 07:37 PM
trev0006
Jan 3, 2009 02:40 PM
KamilEvolution
Jul 15, 2008 04:32 PM
Andrus
Jun 17, 2008 09:53 AM
