2011 honda crv ex l problem with vents
Old Oct 12, 2024 | 10:25 PM
Killerzero's Avatar
Default 2011 honda crv ex l problem with vents
Hey guys so I’ve looked everywhere not sure what to do at this point but my crv sometimes the vents have very little air coming out of them when on max fan speed , you can hear the blower motor speed up and slow down as you use the controls so I don’t think that’s the issue I did replaced the hvac mode door actuator and didn’t seem to fix the issue. When the car was producing little air I checked to see if the actuator was functioning properly which it is , same with the blend door actuator working fine . Engine and cabin filter are pretty clean, coolant looks clean and is full, and yes my vents are open all the way so not sure what’s going on it’s starting to get cold here and have no heat sometimes going to work
Old Oct 13, 2024 | 08:24 PM
So when on defrost, vent, floor etc where does the air go?
Old Oct 14, 2024 | 06:10 AM
Killerzero's Avatar
Seems like it’s going out all the right spots when changing modes just very little air coming out even on max
Old Oct 14, 2024 | 02:29 PM
Did you see that the ducts are not warped or seated wrong? Check at the motor.
JoeGeds
Feb 28, 2023 04:02 PM
Dave Boucher
Oct 10, 2019 05:53 PM
madabouthonda1
Nov 25, 2015 08:47 PM
