2021 CRV Hybyrd EXL
Old Dec 28, 2023 | 10:23 AM
Crvhybyrdmom's Avatar
Default 2021 CRV Hybyrd EXL
My 2021 CRV Hydbird lost pressure, engine lit came on and the power went down to 30 mph from 60mph.
Had it towed to the dealership because of extended warranty and to make sure using oem parts.
Version spark plug #4 miss firing and leaking valve gasket. I feel for a car just under 3 years old with 40, 000 miles where all maintenance has been done should not be having this problem.
As anyone else experienced this?
Old Dec 28, 2023 | 12:19 PM
Just Ducky's Avatar
Default High Birds
Based on the way you describe the basis for your question, I assume that you did/do not follow the recommendation in your owners manual to use top-tier gas. Sooooo, because you have an Atkinson Cycle engine I would estimate that it would be possible to wear out a valve “gasket” over the course of 40k mi. If my assumption is incorrect then it would not be normal to experience that type of failure within the parameters specified.
Also, if the proper break in was not performed that too could have contributed to your premature part failure.
YMMV
Ref: pg 476 for break in
pg 572 for top tier
Old Dec 28, 2023 | 07:20 PM
YMMV
pg 572 for top tier
I followed the fuel recommendations in the owners manual., which is unleaded gasoline pump octane 87 or higher. The top tier detergent was only endorsed by Honda not recommended as per the owner's manual. As for proper break in, this is not my first hybrid. I followed all guidelines outlined in the owner's manual and performed every recommendation or maintenance as requested. The code was P0304 which is a misfire of cylinder No.4. I was surprised a valve adjustment was needed over a misfire.
Old Dec 28, 2023 | 07:40 PM
Just Ducky's Avatar
Default Descriptors
I guess I did not understand what you were asking. We went from “valve gasket” to valve adjustment and added P0304 code. I’m also clueless as to exactly what “lost pressure” and “Version spark plug” is actually referring to.
As for your differentiation between endorsement and recommendation, I look at a recommendation as a strong suggestion and an endorsement as a positive recommendation.
Hope you find the answer you are looking for.
Out
don9902
Oct 2, 2022 05:54 AM
01snowman
Feb 12, 2020 02:03 AM
Fdxdad1
Apr 5, 2019 09:27 AM
axr0284
Jan 31, 2014 07:44 AM
hbfireman
Jul 18, 2008 08:35 AM
