acmech52 |
08-13-2019 08:44 PM |
welcome to the forum. if you intend to tow for a short distance, you will not need the weight distribution bars or brakes on the trailer. if you intend to drive this a long distance, you would be pushing your luck a bit. with weight distribution bars, trailer brakes, and trans cooler, you're still 500lbs over capacity. my experience was with a 7200lb trailer being towed by a 1/2 ton dodge truck, with weight distribution bars, trailer brakes, trans cooler, standard trans. i lost my left rear wheel when the lugs elongated the rim holes. too much weight to pull, 3/4 to 1 ton truck should have been used. not advisable to go over capacity for any long runs.
