98 crv idle issue
I have a 1998 Honda CRV with an idle fluctuation issue I have cleaned out the (FICV) fast idle control valve on the throttle body I have replace the MAP sensor and I have replaced the (IACV) idle air control valve and the car is full on coolant I have also sprayed starting fluid around all vacuum lines to see if there is a vacuum leak and I have replace the intake manifold gasket as well as throttle body gasket.Any ideas?
Did you clean the throttle body?
98 Honda crv idle issues
Yes I did
Are you sure the new intake gasket was installed in the proper position?
(Post 43215)
Get OEM.
(Post 43222)
Get OEM.
