98 crv idle issue
Old Oct 3, 2023 | 10:52 PM
notnathanntv's Avatar
Default 98 crv idle issue
I have a 1998 Honda CRV with an idle fluctuation issue I have cleaned out the (FICV) fast idle control valve on the throttle body I have replace the MAP sensor and I have replaced the (IACV) idle air control valve and the car is full on coolant I have also sprayed starting fluid around all vacuum lines to see if there is a vacuum leak and I have replace the intake manifold gasket as well as throttle body gasket.Any ideas?
Old Oct 4, 2023 | 09:07 AM
Did you clean the throttle body?
Old Oct 4, 2023 | 05:59 PM
Default 98 Honda crv idle issues
Yes I did
Old Oct 4, 2023 | 08:02 PM
Are you sure the new intake gasket was installed in the proper position?
Old Oct 5, 2023 | 07:31 PM
yes the codes that the car is throwing is idle air control system P0505 cat system bank one below efficiency P0420 evap emissions leak P1457 and that’s it only thing I can think of is it’s a bad IACV I bought it off Amazon for $50 and Ik there is 4 different ones and idk which one is the correct one to get
Old Oct 5, 2023 | 07:57 PM
Get OEM.
Old Oct 5, 2023 | 10:09 PM
Get OEM.
do they still sell oem
purplebelt15
Mar 2, 2015 10:35 PM
Rynovdw
May 24, 2011 04:38 AM
2002odysseyowner
Jul 13, 2009 01:18 PM
swsdthumphries
Nov 2, 2008 10:41 PM
HondaMaren
Apr 15, 2007 09:43 AM
