problem with idle HELP!
Old Nov 1, 2008 | 05:18 PM
swsdthumphries's Avatar
Default problem with idle HELP!
Hi everyone new to this. But I have a 1996 honda accord and from time to time my idle will go up and down to the point where it feels like it is about to turn off. I filled it with antifreeze and it still does it. Also my check engin light is on and a mechanic said that it was a gsr sensor or valve not sure but does anyone know what i can do to fix these problems?
Old Nov 2, 2008 | 10:41 PM
Default RE: problem with idle HELP!
welcome to the forum. throttle position sensor or map sensor,may cause your idle to go up and down when warm, if cold it could be the idle control valve.also there is a bleed for the anti-freeze when you replace the fluid, it should be bled.
bcole6
Apr 30, 2013 09:30 AM
RotnikVW
Feb 28, 2007 01:55 AM
Corbuston
Feb 4, 2007 03:04 AM
alexk
Feb 1, 2007 11:24 PM
BigDan
Jul 25, 2006 12:22 AM
