Brake fluid
I am looking to flush the brake fluid on my 2006 HONDA CR-V 4WD, but I cannot find to buy Honda Heavy Duty DOT-3 Brake Fluid. The Oil Stores offer only DOT-4 fluid. Can anyone tell me that I can use that kind of fluid, or what else? I have no acces to a Honda Dealer Service Shop. Thank You!
2006 cr-v owners manual says to use DOT 3 "Honda Fluid" you can get honda fluid from the internet honda dealers selling them, shipped to you. don't need a dealer in your area. and use as much as needed to do a full flush. The manual also says if you use and aftermarket oil, it may cut the life of the unit down.
I just bled the brakes on my 2010 civic using honda brake fluid. Members on other forum seem to think that most brands heavy duty dot 3 , even dot 4 is ok. I will not substitute other brands for the transmission fluid, steering pump fluid and radiator coolant .
