Change 2016 CRV Date
Old Jan 8, 2023 | 10:32 AM
luckydxx's Avatar
Default Change 2016 CRV Date
Dear members, I changed the battery and the date became Dec 31 2012. not on LCD screen but on dashboard screen(intelligent Multi-Information Display). I searched no where found solution. Previous thread mention HOME+power+eject, not sure what is eject, is the button to open the cd case? If it is, tried but not able to get in hidden dianostic menu. Please help with your previous experience. thank you so much
please help change the date
Old Jan 8, 2023 | 12:55 PM
Quick Reference Guide
● Press the (Eject/CLOSE) button to open the screen.
Models with two displays
i-MID
(Power) Button
(Home) Button
VOL (Volume)
Buttons
(Menu) Button
(Back) Button
(Eject/CLOSE)
Button
Button
Audio/Information Screen
Microphones
return the screen to the upright position.
(Eject/CLOSE) Button CD Slot
16 CR-V-31T0A6400.book 18 ページ 2016年4月6日 水曜日 午前10時55分19
Driving (P 351)
Release Button Shift Lever
Depress the brake pedal and press the
release button to move out of (P.
Move the shift lever without
pressing the release button.
Press the release button to
move the shift lever.
Continuously Variable Transmission (P 372)
● Shift to (P and depress the brake pedal when starting the engine.
● Shifting
Park
Turn off or start the engine.
Transmission is locked.
Reverse
Used when reversing
Neutral
Transmission is not locked.
Drive
Normal driving.
Drive (S)
● Better acceleration
● Used to increase engine braking
● Used when going up or down hills
Low
● Used to further increase engine braking
16 CR-V-31T0A6400.book 19 ページ 2016年4月6日 水曜日 午前10時55分
69
Instrument Panel
This chapter describes the buttons, indicators, and gauges that are used while driving.
Indicators ............................................ 70
Display Warning and Information
Messages * ....................................... 88
Gauges and Displays
Gauges............................................ .. 94
Information Display * .......................... 95
Multi-Information Display * ................. 98
intelligent Multi-Information Display (i-
MID) .............................................. 113
* Not available on all models
16 CR-V-31T0A6400.book 69 ページ 2016年4月6日 水曜日 午前10時55分
70
Instrument Panel
Indicators
*1:Models with the smart entry system have an ENGINE START/STOP button instead of an ignition switch.
Indicator Name On/Blinking Explanation Message *
Parking Brake
and Brake System
Indicator (Red)
● Comes on for a few seconds when
you turn the ignition switch to ON
(w*1, then goes off if the parking
brake has been released.
● Comes on when the parking brake is
applied, and goes off when it is
released.
● Comes on when the brake fluid level
is low.
● Comes on if there is a problem with
the brake system.
● The beeper sounds and the indicator
comes on if you drive with the
parking brake not fully released.
● Comes on while driving - Make sure the
parking brake is released. Check the brake
fluid level.
2 What to do when the indicator comes
on while driving P. 511
● Comes on along with the ABS indicator
- Have your vehicle checked by a dealer.
2 If the Brake System Indicator (Red)
Comes On P. 511
Low Oil Pressure
Indicator
● Comes on when you turn the ignition
switch to ON (w*1 , and goes off
when the engine starts.
● Comes on when the engine oil
pressure is low.
● Comes on while driving - Immediately
stop in a safe place.
2 If the Low Oil Pressure Indicator Comes
On P. 509
U.S.
Canada
(Red)
16 CR-V-31T0A6400.book 70 ページ 2016年4月6日 水曜日 午前10時55分
71
uuIndicatorsu
Continued
Instrument Panel
Malfunction
Indicator Lamp
switch to ON (w*1
, and goes off
when the engine starts, or after
several seconds if the engine did not
start. If “readiness codes” have not
been set, it blinks five times before it
goes off.
the emissions control systems.
● Blinks when a misfire in the engine's
cylinders is detected.
● Readiness codes are part of the on board
diagnostics for the emissions control
systems.
2 Testing of Readiness Codes P. 525
● Comes on while driving - Have your
● Blinks while driving - Stop in a safe place
where there are no flammable objects. Stop
the engine for 10 minutes or more, and wait
for it to cool down. Then, take your vehicle
to a dealer.
2 If the Malfunction Indicator Lamp
Comes On or Blinks P. 510
Charging System
Indicator
switch to ON (w*1, and goes off
● Comes on when the battery is not
charging.
● Comes on while driving - Turn off the
heating and cooling system */climate control
system * and rear defogger to reduce
electricity consumption.
2 If the Charging System Indicator Comes
On P. 509
Shift Lever
Position Indicator
● Indicates the current shift lever
position.
2 Shifting P. 372 —
16 CR-V-31T0A6400.book 71 ページ 2016年4月6日 水曜日 午前10時55分
128
uuGauges and Displaysuintelligent Multi-Information Display (i-MID)
Instrument Panel
Selecting a wallpaper
1. Press the MENU button.
2. Select Customize Settings with the (+ /
(- button, then press the SOURCE button.
3. Select Display Setup with the (+ / (-
4. Select Select Wallpaper with the (+ / (-
5. Select the image file you want with the (+ /
u When the scroll is stopped, the
thumbnail is displayed.
6. Press the MENU button to exit the
customizing screen.
16 CR-V-31T0A6400.book 128 ページ 2016年4月6日 水曜日 午前10時55分129
Controls
This chapter explains how to operate the various controls necessary for driving.
Clock .................................................. 130
Locking and Unlocking the Doors
Key Types and Functions .................. 132
Low Smart Entry Remote Signal Strength *...134
Locking/Unlocking the Doors from the
Outside .......................................... 135
Locking/Unlocking the Doors from the Inside ...139
Childproof Door Locks ..................... 140
Auto Door Locking/Unlocking .......... 141
Opening and Closing the Tailgate... 142
Security System ................................ 149
Immobilizer System .......................... 149
Security System Alarm * .................... 149
Opening and Closing the Windows..... 152
Opening and Closing the Moonroof* .. 154
Operating the Switches Around the Steering Wheel
Ignition Switch................................. 155
ENGINE START/STOP Button............. 156
Ignition Switch and Power Mode
Comparison ................................... 159
Turn Signals ..................................... 160
Light Switches.................................. 161
Fog Lights * ...................................... 164
Daytime Running Lights ................... 165
Wipers and Washers ........................ 166
Brightness Control ........................... 169
Models without smart entry system
Models with smart entry system
Defogger/Heated Door Mirror * ........ 170
Driving Position Memory System * .... 172
Adjusting the Steering Wheel .......... 174
Adjusting the Mirrors....................... 175
Interior Rearview Mirror ................... 175
Power Door Mirrors ......................... 176
Adjusting the Seats .......................... 177
Adjusting the Seat Positions............. 177
Interior Lights/Interior Convenience Items .. 187
Heating and Cooling System* ......... 200
Using Vents, Heating and A/C.......... 200
Climate Control System* .................. 203
Using Automatic Climate Control .... 203
Automatic Climate Control Sensors... 206
16 CR-V-31T0A6400.book 129 ページ 2016年4月6日 水曜日 午前10時55分
130
Controls
Clock
Adjusting the Clock
The navigation system receives signals from GPS satellites, updating the clock
automatically.
You can adjust the time in the clock display with the ignition switch in ON (w*1.
■ Using the MENU button
2. Select Adjust Clock with the (+ / (- button, then press the SOURCE button.
3. Press the (+ / (- button to change the
setting between 12h and 24h.
4. Select hour or minute with the /
button.
5. Press the (+ / (- button to adjust the
numbers up or down.
6. Select Set with the / button, then
press the SOURCE button to enter your
selection.
u The display will return to the Adjust
Clock display.
*1: Models with the smart entry system have an ENGINE START/STOP button
Models with navigation system
All models
Models with one display
16 CR-V-31T0A6400.book 130 ページ 2016年4月6日 水曜日 午前10時55分131
uuClockuAdjusting the Clock
Controls
■ Using the SETUP button
1. Press the SETUP button.
2. Rotate to select Adjust Clock, then press .
3. Rotate to select the item you want to change (12/24 hour mode, hour,
minute). Then press .
4. Rotate to make the adjustment.
5. Press to enter your selection. The display returns to Adjust Clock. Repeat steps
4 to 6 to adjust other items.
6. To enter the selection, Rotate and select Set, then press .
7. Press the SETUP button to go back to the normal display.
■ Using the audio with touch screen
1. Press the (Home) button, then select
Settings.
2. Select Clock/Info, then Clock
Adjustment.
3. Adjust the hours and minutes by selecting
4. Select OK to set the time.
1Using the SETUP button
These indications are used to show how to operate
the selector ****.
Rotate to select.
Press to enter.
To set the time to the nearest hour:
Press and hold the CLOCK button until the clock
display begins to blink, then press the (6 (Reset)
button.
Depending on the displayed time, the clock sets
forward or backward.
Example:
1:06 will reset to 1:00
1:53 will reset to 2:00
(Home) Button
3 4
1Using the audio with touch screen
You can customize the clock display to show the 12
hour clock or 24 hour clock.
2 Customized Features P. 274
16 CR-V-31T0A6400.book 131 ページ 2016年4月6日 水曜日 午前10時55分
132
Controls
This vehicle comes with the following key:
Use the key to start and stop the engine, and
to lock and unlock the doors and tailgate. You
can also lock and unlock the doors and
tailgate pressing the buttons on remote
transmitter.
■ Keys
1Key Types and Functions
All the keys have an immobilizer system. The
immobilizer system helps protect against vehicle
theft.
2 Immobilizer System P. 149
The keys contain precision electronics.
Adhere to the following advice to prevent damage to
the electronics:
• Do not leave the keys in direct sunlight, or in
locations with high temperature or high humidity.
• Do not drop the keys or set heavy objects on them.
• Keep the keys away from liquids.
• Do not take the keys apart except for replacing the
battery.
If the circuits in the keys are damaged, the engine
may not start, and the remote transmitter may not
work.
If the keys do not work properly, have them
inspected by a dealer.
Ignition Keys with Remote
Transmitter *
Smart Entry Remote *
16 CR-V-31T0A6400.book 132 ページ 2016年4月6日 水曜日 午前10時55分
pantefo
Sep 17, 2020 06:09 AM
tebert
Apr 28, 2017 01:36 AM
PCollen
Apr 6, 2017 12:01 PM
