Cr-v multiple misfire
Old Jul 23, 2022 | 10:04 AM
bam32569's Avatar
Default Cr-v multiple misfire
I have a 2007 CR-V, multiple misfire. Cat was plugged up, changed that to get acceleration back but still had a misfire with the triangle and VSA lite on. Did a compression test, adjusted valves, new plugs,coils and injectors. A Still multiple misfire. I've been a tech since 1972, but this one had me stumped. Start out side the box. Cleaned all grounds checked all connectors for corrosion. Checked the alternator for voltage spike. BINGO BAD DIODE. Replaced alternator, no codes runs like a new one. Hope this helps
Old Jul 23, 2022 | 12:21 PM
AC ripple can cause problems with all the electronics and modules. It's easy to test for. With the diode out it likely had pulsating lights.
Old Jul 23, 2022 | 12:37 PM
bam32569's Avatar
Didn't have pulsating lights, did have VSA. Not communicating with engine controller
Chris Martin
Jul 26, 2022 05:43 PM
cutlas
Jan 23, 2016 06:08 AM
brikcity
Jan 9, 2009 04:32 AM
akaha
Nov 26, 2008 08:02 PM
billybop45
Mar 19, 2008 03:01 AM
