Empty fuse positions for dashcam
Old Jul 11, 2021 | 09:08 PM
markfer's Avatar
Default Empty fuse positions for dashcam
Hey all,
I'm planning on installing a dual dashcam and hardwiring with an inline battery cutoff thing (stop from killing the battery).
I was doing some voltage meter checks and I have 2 empty spots with no fuses that show constant on, 1. The tow fuse 2. Moonroof. I don't have either of these in my vehicle. Pos 10 and 11 (circled red).
I'm wondering if I can simply use the empty fuse positions on the fusebox instead of the tap-a-fuse or add-a-fuse options to get protected power from the battery. Irathwr do this than piggy back onto an existing fuse.
Old Jul 11, 2021 | 10:48 PM
Unless you have the service manual that lets you know where those fuses comes out, it is quite a job to trace the circuit to find where to connect to.
Of course, you can always get lucky and find the connection??
And, why not connect to a fuse that is only hot when key is in accessory or on??
Old Jul 24, 2021 | 02:19 PM
markfer's Avatar
The dashcam has an option to run in park, having a motion sensor and therfore ignition off therfore catching anyone who hits and runs. For that I need constant power.
Old Aug 20, 2021 | 08:18 PM
thangnguyen02's Avatar
Will follow this thread. I'd like to install a used dashcam from my old vehicle too, but so far idk which slots to use.
2008HondaOdyssey
Jan 15, 2021 08:48 PM
wheatieman
Dec 3, 2018 01:45 PM
butterbean65
Dec 31, 2012 01:44 PM
thomis
Sep 11, 2012 02:36 PM
dahuckman15
Jul 13, 2007 01:16 AM
