Engine Fitment
Replacing the engine in a friend's 2001 CRV, B20, 5 Speed.
Engine proposed came from same year but with Auto Transmission. Should I expect any issues? Tia.. Tom Maxey Floyd, Va |
you may need the ecu for the auto transmission. drive shaft different, you might want to view the parts list at cheaperhondaparts.com to compare. trans, drive shaft, mounts, radiator cooling, cooling lines. shifting control,
Originally Posted by acmech52
(Post 36197)
engines should be all the same. if from like cr-v. ( sorry i read it back wards, thought the trans was going to be change)
(Post 36203)
