Engine Fitment
Old Oct 6, 2020 | 11:17 AM
Tom Maxey's Avatar
Default Engine Fitment
Replacing the engine in a friend's 2001 CRV, B20, 5 Speed.
Engine proposed came from same year but with Auto Transmission.
Should I expect any issues?
Tia..
Tom Maxey
Floyd, Va
Old Oct 7, 2020 | 01:00 AM
you may need the ecu for the auto transmission. drive shaft different, you might want to view the parts list at cheaperhondaparts.com to compare. trans, drive shaft, mounts, radiator cooling, cooling lines. shifting control,
Old Oct 7, 2020 | 09:22 AM
Tom Maxey's Avatar
The engine should bolt up ok to the manual tranny with no issues, right? I'm just changing the motor...IE the flywheel and clutch assembly should bolt to the crankshaft...
Old Oct 7, 2020 | 10:24 PM
engines should be all the same. if from like cr-v. ( sorry i read it back wards, thought the trans was going to be change)
Old Oct 9, 2020 | 12:40 AM
Tom Maxey's Avatar
Thanks!
Steph Leslie
Jul 30, 2020 09:14 PM
Pierre Martin
Apr 30, 2020 11:40 PM
AlexDuran
May 23, 2008 08:48 AM
ailwyn
Nov 9, 2006 11:27 AM
