fan blower control
I have an 04 crv when I turn on fan switch it may turn blower motor on and it may not. sometimes it may come on by itself. does anyone know if that dial switch could go bad in that manner. I would also like to know if there is a relay between the fan blower switch and the actual blower motor itself. if so where might it be located. any help would truly be appreciated.
thanks j.a.h. |
bump!
Hi there! I was wondering if you were able to fix your problem. Did you manage to pinpoint the main problem, is it just the blower control or the blower motor itself? Well, my cousin is also experiencing some problems over the a/c blower control because it only works on high speed fan. Can you share to me what did you do to fix the problem? Other opinions to fix this would be helpful too. |
If it only works on High then it is indeed the switch.
