fan blower control
Old Mar 8, 2008 | 06:26 PM
jah's Avatar
jah
Default fan blower control
I have an 04 crv when I turn on fan switch it may turn blower motor on and it may not. sometimes it may come on by itself. does anyone know if that dial switch could go bad in that manner. I would also like to know if there is a relay between the fan blower switch and the actual blower motor itself. if so where might it be located. any help would truly be appreciated.
thanks
j.a.h.
Old Jan 19, 2011 | 09:41 PM
elijah's Avatar
bump!
Hi there! I was wondering if you were able to fix your problem. Did you manage to pinpoint the main problem, is it just the blower control or the blower motor itself? Well, my cousin is also experiencing some problems over the a/c blower control because it only works on high speed fan. Can you share to me what did you do to fix the problem? Other opinions to fix this would be helpful too.
Old Jan 25, 2011 | 09:29 AM
If it only works on High then it is indeed the switch.
palomino
Sep 28, 2009 09:34 PM
johnfm3
Jul 19, 2009 02:42 AM
sdharwar
Apr 22, 2009 05:50 AM
Brentwoodupser
Jan 22, 2009 11:41 AM
PW01
Aug 1, 2006 04:13 PM
