help with po1164
Old Feb 15, 2026 | 04:04 PM
n1xwl's Avatar
Question help with po1164
Hello to all
I’m new to the site. I recently bought a 2003 CR-V LX mainly for work and around town, and it has 23,056 miles on it. The SEL light was on due to the upstream O2 sensor not receiving a signal, and the VTC solenoid was also not functioning because the connector was broken. I replaced both components, but now the SEL light shows code P01164. While driving, the car intermittently buckles
, and the RPMs surge at idle. I’m looking for help on where to start diagnosing the issue. Could it be that the VTEC screen needs cleaning? Thanks in advance for any advice!
Old Feb 15, 2026 | 09:04 PM
Just Ducky's Avatar
Default Amazing Find
So you have an 03 with 23k miles. That is amazing.
Your DTC is P1164. It is telling you that the air/fuel sensor is suspect. Locate the sensor and check the connectors.
CEL is a check engine light. It does not give codes.
Old Feb 16, 2026 | 05:26 AM
n1xwl's Avatar
thanks for the reply the mileage was a type o when I bought the vehicle last week the code read no signal received from sensor bank 1 install ne o2 sensor and now the 1164 I've check the wire& connector check out ok
Motorhead
Mar 1, 2025 04:18 PM
cyberwizard
Aug 29, 2023 10:34 AM
Benlee1199
Aug 7, 2023 01:22 PM
parts_per_million
Jan 28, 2020 06:41 PM
jimmyjet10
Feb 20, 2017 07:53 PM
