Honda 1998 ex
Old Dec 1, 2024 | 05:53 PM
rondofc1's Avatar
Default Honda 1998 ex
i have honda crv 1998 ex for some reason my breaks wont break i took it to les Schwab so they can bleed the brakes the whole system and they told me that the breaks i will not hold pressure and they told me that the abs Module is bad thats what they said when i break i have to break all way down
to floor order to break someone can put me in the right direction or causes problem
Old Dec 1, 2024 | 06:09 PM
Just Ducky's Avatar
Assuming no fluid leak and your brakes (breaks) work, the ABS Modulator or Control box may not be the issue unless you are getting a warning light for ABS. Check for DTC codes first.
I’d be inclined to look at the Booster next. That is the big black round thing the master cylinder is attached to with a vacuum line from the intake.
Dwauynxts
May 27, 2023 10:06 PM
angelh
Dec 21, 2016 03:28 AM
Diamond T
Jan 29, 2013 07:13 PM
silverbullet
Apr 3, 2007 04:41 AM
silverbullet
Feb 1, 2007 06:26 PM
