Horrible rear diff noise/shudder/jumping
Old Nov 28, 2018 | 03:55 PM
billdoodle's Avatar
Default Horrible rear diff noise/shudder/jumping
Rear diff is sounding like the entire rear end of the car is dropping out whenever rear wheels kick into 4wd. I'm on my second rear diff and the problem still exists. It is a 2001 manual five speed so could it be the front splines for the drive shaft slipping/jumping causing this problem. I'm totally clueless as to why this is such a violent shaking/jumping.
Old Nov 28, 2018 | 08:30 PM
welcome to the forum. wow, sounds like something has worn out or broken. when a rear end tooth breaks, it will make a banging noise if the teeth are worn out bad, it will howl. i have not seen worn splines on the drive shaft, jumping sometimes comes from oil on the clutch plate.
Low_Key_Slaps
Jan 29, 2019 11:14 PM
kristin.barlow@gmail.com
Aug 13, 2016 08:54 AM
poppies18
Apr 14, 2009 03:13 PM
adamtb1977
Jun 25, 2008 10:52 AM
