How to make Backseat lay flat
Old Mar 10, 2019 | 09:48 AM
My First Honda's Avatar
Default How to make Backseat lay flat
Hi, I have a 2017 CRV. When I bought it I was told that you can make the backseats lay flat. However, when I put the seatbacks down there is a 1 inch height difference between the trunk cargo space and the backs of the seatbacks cargo space because the seatbacks are laying on top of the bottom cushions. (I hope that makes sense!) In my last car (Ford Focus hatchback), I was able to lift the bottom cushions out of the way for a seamless, flat open cargo space. But I can’t figure out how to do that on the CRV. Is there a lever? Or button? Thanks for your help!
Old Mar 10, 2019 | 05:32 PM
Lochinvar's Avatar
What does your owner's manual have to say about it?
Old Mar 10, 2019 | 08:21 PM
Of course I checked the manual. It does not say anything about the bottom cushion. It didn’t say anything about the bottom cushion in my Ford manual either- someone told me about it. Despite not being in the manual the CRV was marketed as having a flat cargo space when the backseat is down. It is not flat with the cushions in the way. So if you know how to move the bottom cushion or that the CRV was improperly advertised then that would be helpful. If you don’t know anything then no need to respond. Thanks.
Old Mar 11, 2019 | 02:06 AM
welcome to the foum. lift your back seat (where a person would sit on ) up to the back rest and place the bar flat to the bottom of the seat holding it up as you are doing this, remove your head rest if needed then release your latch like you did and put the seat and back rest down flat. be gentle not to drop the whole seat down, then you will have a flat area. make sure first nothing is under the seat or it will get flattened out. I apologize for the slow response, helping a senior friend who lost his life and its a lot of time consuming work.
Old Mar 11, 2019 | 06:04 AM
acmech52, I’m so sorry to hear about your friend. Thank you for taking the time to respond, especially during this difficult time. I will try your suggestion and will let you know if I run into problems. It sounds like the bottom cushion should just pull up without a release mechanism. My old car was the same way, but perhaps I wasn’t pulling hard enough for the CRV. Also, thanks for the info about the bar. Best of luck managing your friend’s matters.
Old Mar 12, 2019 | 12:48 AM
thank you for your kind words.
Old Mar 12, 2019 | 07:58 AM
Would look on youtube ... search for tips and tricks for Honda CRV
Some seats just fold forward others the seat cushion folds up and back rest goes down
Depends on your CRV
Old Nov 18, 2019 | 05:28 PM
kayakterp's Avatar
I just joined this site - we have a 2016 CR-V SE - do you happen to know if the 2016 is the same way - I would love to have my back seats lay totally flat if mechanically possible!
Thank you
dougpend
Sep 28, 2018 03:06 PM
PBobby
Jun 14, 2018 12:42 PM
tmbdab
Apr 29, 2018 06:39 PM
MrsC
Jul 26, 2017 01:44 PM
highs on bass
Jul 10, 2014 11:23 AM
