I/M readiness greenlight still throwing code
I've got a 2006 honda crv SE auto. I'm trying to get it inspection ready but it keeps throwing p0420. I've addressed the obvious issues from the trash shop I got it from. I fixed their atrocious "welding" job on their half-assed exhaust fix,the cat is new and the o2 sensors are new. I did a vacuum test to find leaks and even replaced the pcv valve and hose to eliminate potential exhaust contamination. Here's where it gets interesting. I check the readiness and I've got the green light across the board including the cat. Despite this, p0420 is still there. I did leave it there after the pcv valve was replaced to see if it would clear itself. Should I clear it and let it go another cycle or is there something else going on? Any ideas would be helpful.
Originally Posted by Mr.Black
(Post 40465)
welcome to the forum. you mentioned the cat and sensors were replaced. were they after market sensors and cat.? asking because it it came from a Trash Shop, they put on normally after market parts. Honda's don't like after market parts. the cat is 1800.00 and the after market sensors are denso type but Honda mods the sensor to suit their vehicles not multi use type.
(Post 40467)
Are we supposed to know what this is?
I eliminated all exhaust leaks. |
Who made the cat and O2 senors?
Would clear the codes and run the vehicle to see if it comes back.
If it goes green and no new codes then you are all set. If the code comes back then should revisit the definition of the DTC. It might give you a new perspective. |
(Post 40472)
(Post 40465)
(Post 40481)
I couldn't tell you who made the parts. I didn't buy or install them. According to the dealership "some crackhead came into the lot and hacked off the original". Judging from the "work" they did on the exhaust I'm sure they aren't even mid range parts. If they couldn't take 10 minutes to properly weld anything or better yet just replace the resonator pipe instead of hacking off the flange on the new cat, I'm sure they didn't invest much.
you might want to start from scratch, replace the cat with a honda original, and the sensor with honda original. cost of parts may exceed cost of car's worth.
(Post 40483)
So you did this work. Good
You say you did the work and then you say they did the work. All I know is you have a problem with your car and also a problem trying to explain it. |
