ignition key fault
Old Feb 13, 2022 | 12:11 PM
sruggieri09's Avatar
Default ignition key fault
Hi everyone just joined forum, just wondering as anyone had problems with the ignition key, my key gets stuck in the ignition barrel once I've parked the vehicle, its becoming a real nuisance now, on a couple of occasions I have to leave the key in the ignition barrel, any advice would be much appreciated Thanks
Old Feb 13, 2022 | 11:23 PM
Have you tried lubricating the barrel?
Sometimes the barrel gets gunked up.
Some lube might help
Have you tried moving the gear selector thru the gears and back into park?
There is a switch in the gear selector which tells the vehicle if the it is in park.
If the switch is becoming faulty then it could present the same symptoms.
Old Feb 14, 2022 | 01:09 AM
Hi there, I'll try and spray lube , hopefully that will solve the problem, the issue started all at once, not a gradually thing, unfortunately it's a manual and not a automatic, thanks for replying much appreciated 👍
Old Feb 14, 2022 | 07:45 AM
Hope that resolves the issue. If not then may be time to shop for ignition cylinder locks???
Hope for the best and prepare for the worse.
Iceberg9
Jul 12, 2021 09:03 AM
Tina Congdon-Burnett
May 31, 2021 08:43 PM
GrodanBoll
Aug 28, 2017 04:24 AM
darius25
Nov 20, 2012 06:52 PM
derek123
Nov 26, 2006 07:31 PM
