M4 x 1.5 mm hex/phillips head screw - Can't Find!
Old Aug 4, 2025 | 08:29 PM
mormegil27's Avatar
Unhappy M4 x 1.5 mm hex/phillips head screw - Can't Find!
I need to replace a screw used to secure the Honda CR-V 2011 EX-L HVAC door mode actuator. The screw has the following specs:
Major Diameter = 4 mm (M4) (Guess it might be 5/32)
Thread Pitch = 1.5 mm (approximately)
Length = 16 mm
Head = Hex + Phillips combo
Head Diameter = 7 mm wrench
I cannot find this screw anywhere... what is this and where do I find it?????? The Mode Door Actuators do NOT come with fastener screws.
Please help !!!!!!
Old Aug 5, 2025 | 06:29 AM
Just Ducky's Avatar
Default Scr’wd
Can you find the reference number here?
https://www.hondapartsnow.com/parts-...ater_unit.html
Old Aug 8, 2025 | 04:06 PM
mormegil27's Avatar
Yes, thank you so much! It is this screw:
https://www.hondapartsnow.com/genuin...7-s84-003.html
Denvernative321
May 28, 2023 12:51 AM
VivaLaOC
Mar 25, 2021 06:17 PM
Albert Cox
Dec 19, 2019 12:12 AM
209xintegra
Dec 9, 2009 02:24 PM
manyahonda
Sep 3, 2008 10:46 AM
