Problem with daytime running lights
HI, I have a 2015 CRV that has recently developed a problem with the daytime running lights.
Last week, I had to replace my main headlight bulb on the driver's side. Of course that's an easy fix but at the same time I noticed the daytime running light on that same side was not working. The passenger side DRL works just fine. As part of my troubleshooting, I removed both fuses (under the hood fuse box and under the dash fuse box) for the DRL BUT the passenger side DRL is still on. So I have 2 questions.. How can the passenger DRL still be on after I removed both fuses? How do I fix the broken DRL on the driver's side? Thanks. |
Is anybody going to give me an answer to this? I posted this question 7 days ago and I haven't received a single response. If this isn't a good place to go to for answers about Honda cars, please redirect me to a place that I can go to.
Thanks |
I need the wiring diagrams for it.
Thanks for your answer. Any idea where I can get the wiring diagram?
You can get the factory info here.
I can probably get it from one of the guys at iAtn but that may take a couple days. If you want me to get it I'll need the vin. |
Thanks. I'll look into that.
When I went to that link, my model isn't listed in the dropdown menu.
The only thing I can do requires your vin umber.
