Rear differential 2003
Old Apr 19, 2021 | 11:54 AM
Uptonlb's Avatar
Default Rear differential 2003
I am currently building a awd civic and using a crv rear diff. I have upgraded the lsd to gear x as will and ring and pinion. My question is, does anybody know where I can find the locking nut that goes onto the shaft of the pinion gear. Honda does not provide this part. Or does anyone have the specs on them so I can order? I had to cut the old one off.
Old Apr 24, 2021 | 10:42 AM
CRVguy4's Avatar
try these links
https://www.ebay.com/sch/i.html?_fro...ntial&_sacat=0
https://www.partsgeek.com/catalog/20...indle_nut.html
https://www.oreillyauto.com/shop/b/w...003-honda-cr-v
https://www.hondapartsonline.net/v-2...r-differential
also, I use this for keeping the vehicle running solid, just thought I would throw this in there in case you want to use a good synthetic, up to you:
https://www.searchforparts.com/oil-c...r-v-2.4l-k24a1
Hope this helps!! Let us know if any of those links helped out.
Old Apr 25, 2021 | 07:57 AM
Uptonlb's Avatar
I tried a few spare spindle and axle nuts and they are to small but I appreciate the response. I ended up going to the salvage yard and getting a whole other rear diff. I am gonna take some measurements when I disassemble it.
Old Apr 25, 2021 | 09:25 AM
Wow, you sound like you got a whole shop set up to do these things.
And that you know what your doing. Can I ask why you want to build a AWD civic?
Do you live in a cold climate or do you go off road??
Old Apr 25, 2021 | 10:57 AM
Uptonlb's Avatar
just out of my little garage at my house. I am building a high horsepower k20. High hp and FWD don't go well together for street use. So I decided AWD is the way. Was my little brother's car before he passed so I decided to do what he always wanted to do.
misterteacher
Sep 15, 2017 05:50 PM
Bob Au
Sep 7, 2016 12:58 PM
kristin.barlow@gmail.com
Aug 13, 2016 08:54 AM
adamtb1977
Jun 25, 2008 10:52 AM
